Hello, I have what I think is a "PVC air line" connected to what I think is a "Fisher Controls" propane pressure regulator for my RayPac propane pool heater. Please see the pics I posted. Anyway, the PVC air line got broken underground...it goes down below grade from the regulator...6-8 inches underground and then pops out above ground six feet away (the pic of the PVC by itself like a periscope). What happened it the PVC pipe got bused off below ground level (during a PVC fence installation nearby) and now it's covered up by dirt....and I think the PVC line is probably clogged up under the dirt...I assume this PVC airline is a propane over pressure relief (?)...and if so would it not make sense to just to cut the PVC air line a few inches below where it connects to the regulator...above ground and that would fix the problem of the more than likely clogged pipe...yes? Or is it dangerous to have a propane pressure relief valve so close to the heater itself? The PVC line leaving below the regulator is not needed for any support as the metal pipe is very sturdy. Thank you.
