I appreciate all the help I’ve gotten from this site so much! I feel like if I had been following the pole star recommendations I would’ve been adding gallons of chemicals!
I feel like I’m on the right track but want to make sure that I am adjusting things correctly. Today’s results are-
FC 6
pH 8.0
CH 200
TA 90
CYA 4
Should I be adding chemicals if I am in the “recommended“ range but not in the “ideal“ range?
Pool Math is telling me that I should lower the pH, though it has my recommended range going up to 8.0. Should I go ahead and lower it a bit?
TA is also at the top end of the “recommended“ range, though not in the ideal range and they recommend lowering that as well.
CYA is low still, so I am going to add more of that.
Thanks !
FC 6
pH 8.0
CH 200
TA 90
CYA 4
Thanks !
