- Apr 24, 2022
- 207
- Plaster
- Pentair Intellichlor IC-40
I’m trying to get my levels balanced as I’ll put my SWG in this weekend. I put my salt at 3500 ppm but it’s probably about 3,000 I will be increasing it once I get up and running.
My PH is about 7.7 right now I am currently adding 3lbs of stabilizer to increase to 50 ppm, I know the recommended levels is higher but going into the close of summer, do I need It higher right now?
CH is at 300 ish, me and these tests don’t get a long. Further trading suggests not adding CH and let it increase on its own.
TA- this and ph impact CSI the most. I am at 70 within the ideal range but my csi is -0.27+ especially if my got to 7.6. I am working on keeping it at 7.8 since that’s the ideal level for my CSI.
You’ll see both SS with the different TA levels, is this something I should increase instead of being further negative with the csi reading?
Also, the recommended levels of Chlorine is lower with SWG why is that? CYA level is recommended higher with the SWG, wouldn’t FC follow?
