Good Afternoon,
I have a system with a QUAD60 filter. Lately we've been getting a ton of air being pushed into the pool returns when the pump kicks on. I've had a pool guy out to check the low pressure (pre-pump) plumbing. He replaced gaskets in two of my valves and pressurized the skimmer to the pump. It didn't seem to be leaking anymore.
One thing I noticed was the release valve on top of my Quad 60 was leaking pretty badly. I replaced it and it no longer leaks.
SHortly after the pump turns off I can hear gurgling coming from of the filter housing. It sounds like water is draining out and sucking in air. I suspect that is why I'm getting so much air when initially turning on the pump. Its so bad that if I open the release valve you can hear quite a bit of air coming out before water starts pushing out. Then close it the valve and the plumbing shakes quite a bit as the remaining air is pushed into the pool returns.
Any ideas on what to check next? I recently replaced my multiport valve that sits between pump and filter, that didn't seem to help much.
-TX_JM
-TX_JM
