I am trying to add a tee to my line to remove water from the pool/spa when the water level is too high, like after days of heavy rain.
Should this tee be added after the pump before the filter, or after the filter?
I know I can do it with a tee and two ball valves, may be it's cleaner to use a three way valve? I bought one off Amazon and I noticed the valve has a restriction in it so this one is no good. Can someone recommend if there is a 3 way PVC valve that has no restriction and doesn't cost an arm and a leg, or may be just do two ball valves with a tee.
