My pump continuously cycles between the spa and the pool, no matter what I do in terms of the service panel or using the phone screenlogic app
The schedules I set up on the screenlogic dont work as expected -- for example if I put in a schedule on screenlogic for the pool to run 7A-5P then it randomly switches between the spa and pool.
If I use the outside service panel and set the mode to "pool" it will run the pool for about 30 mins and then switch over to the spa, even if I dont touch the panel again.
I dont get it -- the only thing I can think of is that there's some kind of hidden circuit that forces the pump into spa mode just to keep the lines running periodically?
