So I am trying to be good and do all the weekly cleaning and I went to clean the pump basket. I shut the pump off first. I then proceded to open the basket and clean it. While I did this, I heard a bunch of water leave and I don't remember that happening last time. So I did clean the basket. I also knew I needed to make sure there was water back in, so I turned the pump on under rinse setting. I let that run until I saw water then shut it off swictched to filter and turned the pump back on.
Now it seems as though I have a leak somewhere coming from the pump. I have no idea where to start to check or if I screwed something up. It is not from the basket filter, I did check that. Please help. Thanks.
