- Jan 22, 2022
- 213
- Plaster
- Pentair Intellichlor IC-40
So I recently bought of of those fountains you attach to your returns to try and lower the temp in the pool for the summer. Works great but needs a higher speed on the pump. I already have 4 pump speed options in screen logic (pool,spa,pool high,spillway) and I’m trying add a 5th feature for a “high speed” that’s even higher than pool high To really get the fountain going high.
Issue is that I’ve added it in screenlogic configure just like the other features I’ve done except it’s not a showing under my pump speed options in regular screenlogic. It’s shows under pool mode where I set it, but not the pump. Screenshots below for reference. Is there a max amount of features you can set for pump speeds on a VSF? Or am I doing something wrong here. Thanks!
