Undergoing my first SLAM after draining my pool due to high CYA and CA. I now have everything within recommended range (thanks everyone!). Most of my algae is in the spa. My spa is raised above pool level with a spillway. I understand I need to run the pump continuously during the SLAM but how much time should I run the spillway? My understanding is that the water is pulled from the pool to the spa with this setting. I have it set for 2 hours per day on spillway and 22 hours for pool. Is the filter working when the spillway is going? Thanks all!
