- Nov 30, 2019
- 858
- Fiberglass
- Hayward Aqua Rite (T-15)
Remove it, sand and paint. Don't want the fan shroud to come off, that would allow for damage to the fan, fingers, kittens and disrupt the air flow needed to cool the motor.Is this just a cover on the back end of my SS Hayward pump? Can I just replace it? Or is this a motor replacement? It’s still operating fine (4 years old). Don’t want to wait until it fails, looks to me View attachment 458320like some preventive maintenance is warranted.
I wish it was in good enough shape to do that. It’s so corroded I can stick my finger right through it.Remove it, sand and paint. Don't want the fan shroud to come off, that would allow for damage to the fan, fingers, kittens and disrupt the air flow needed to cool the motor.
Hayward told me the shroud is not available as a separate item. You might try removing as much loose material as you can and get some Flex Tape at a hardware store like Home Depot. Wrap it around the shroud, just don't cover the openings unless you cut them open again. It is good stuff and may hold for quite a long time.I wish it was in good enough shape to do that. It’s so corroded I can stick my finger right through it.
Have you tried all of these ways?I’ve been trying to get hold of Century with no luck.
If the trip was reversed, well, that's just 'up the road' to a Midwesterner.It's not that far, maybe pop in for a visit if they won't answer your call.
There were covers available for other models. I bet there's at least one that would be close enough for government work with a minor tweak or two.Looks like it’s down to fabbing one
I have seen other fan shrouds for their VS motors which look like they might work with modifications. $30 or so. I still think I can make one for less than $10.There were covers available for other models. I bet there's at least one that would be close enough for government work with a minor tweak or two.
