- May 3, 2007
- 18,071
- Plaster
- Hayward Aqua Rite (T-15)
That document perpetuates the turnover myth that we trying to get our members to ignore.
Yes, I lubed it with silocone grease when I opened it up to clean it. I also cleaned and inspected the o-ring. Seemed OK.Have you tried lubing the pump basket lid o-ring?
Also, check the o-ring for any cracks.
This is awesome. Thanks for sharing it. I agree that it sort of perpetuates the myth, but the explanations on TDH are great.I found this Hayward tutorial on pump sizing a few years ago. If you really want to get into the math of pool pump flow.
You gave me hope, but no I checked and it is inserted correctly. The arrow in the cover matches the arrows in the body as well as arrows in inlet/outlet.
This is your return line and the water flows opposite the arrows!You gave me hope, but no I checked and it is inserted correctly. The arrow in the cover matches the arrows in the body as well as arrows in inlet/outlet.
Wait, are you saying the entire fitting is backwards? I thought you meant the cell that you can take out to clean, but you're referring to the entire housing??This is your return line and the water flows opposite the arrows!
Yes, but I think it will work either way.Wait, are you saying the entire fitting is backwards?
There doesn't appear to be an external flow switch so perhaps there is an internal flow switch. But the unit should have alarmed.NOTE If the flow direction of the water does not match the arrows on the housing, the cell will malfunction.
Can you explain how a gas sensor acts as a flow switch?There is no flow switch; it uses a gas sensor like the Australian models.
