Hello,
My name is Chris and I am in need of some experienced advice. I have a 2Hp secondary single speed US motor that is giving me some bearing noises. From the original placement of it I have decided that it is time to replace it. In addition, the pump basket housing is cracked right above the mounting area of the motor. So, I thought about just getting the same exact parts and continuing the status quo but, everything is Jandy. I don't want to continue paying the Jandy price every time something goes out or wrong. So the few questions I need answered are:
- If I need to stay with the same type of pump, what is the equivalent in a variable speed? (Preferably between 1 and 3 horsepower)
- Can I retrofit a Pentair VS pump instead of staying with Jandy?
- If I did go to a VS pump, would it be able to work in unison with my Jandy AquaLink system?
In addition to this information, I will eventually continue to switch everything from Jandy to Pentair - as budget allows... Thanks in advance!
