I am replaceing a very old wfds-8 whisperflo 2 hp with a newly bought intelliflo pump. I had earlier thought about replacing the backend only....however the volutes are different as my whisperflo is from prior to 1998.
My problem is that whoever set up the pump earlier did not leave any extra PVC pipe to cut and attach a new coupling. There is literally less than 1 cm between couplings all the way to the filter valve (MPV). There is one 2" slip PVC Union in between the discharge and the filter line.
Question: How does one redo the pumbling when there is no room to attach a new coupling or extra segment of PVC. Any previous ideas or experience? I thought about replacing one half of the slip union, but I am not too sure If I can buy the exact same type and brand?
Thanks very much for your time
