I have a Pentair Whisper Flow. I just replace the check valve and lubed the gaskets on the wet side of the pump. We have had the circuit breakers turned off to prevent the pump tring to start when pieces were disconnected. When I went to turn the pump back on the timer panel clicks. It immediately goes into spillway mode and there is no sound from the pump at all. Could I have knocked something loose whe I took the end off to clean? Is there some sort of a reset I need to do on the panel? I am a rookie at all of this still--though I have had success fixing the heater a few times.
