My pool pump turns on automatically at 6 AM every morning and runs until 2 PM. I recently replaced my filters and now the pump turns on but does not cycle the water. To get the pump to work I have to go out and turn the Jandy valve to spa drain, this will get water inside the pump basket, I then turn it back to regular filtration and it will run as it should. If I release all the air from the manual air relief then the next day the pump will turn on without having to change to spa drain but only for that day. if anyone has any idea how to fix this please let me know.
