- May 29, 2018
- 409
- Plaster
- Pureline Crystal Pure 60,000
Been here long enough to search threads, ect. but cannot find anything new to try.
I had to blow out my skimmer lines due to I plugged the one closest to the pump when vacuuming thru skimmer.
99% sure line was cleared.
Now I cannot get my pump to prime.
Have tried the following....
Re-lubed the pump cover
Check all unions, drain plugs
water level is fine
poured bucks of water into pump
ran hose into pump back towards skimmers and main drain
tried using any combination of main drain, one skimmer, both skimmers
bleed air from filter as priming
bleed air from filter after priming
pump set for 9 mins of priming
Had this problem in spring when I took pump off line for repairs, but it finally primed after using the hose to skimmers.
Only thing I have not tried is running hose thru skimmers back towards pump.
At a loss what to do/try, I assume the pipes are still full of air.
Chemicals are fine
Pool is app 2-3 feet below pump and app 60 feet away
water level is fine
Chemicals are fine
