I have a new pump on backorder, but to get through this season I ordered a new motor for my failed Superpump. I replaced the motor today but I have seem to have done something wrong as it pours out water from the bottom when I fill the pump basket. It appears to be coming out where the motor meets the motor housing.
I took it apart again and I attempted to tighten the motor housing bolts some more as I remember they were tough to take off. I also flipped the shaft seal as I had it in backwards. Same result though.
I replaced all of the seals except the shaft seal as the new one wouldn't fit.
It did not leak before replacing the motor and I had even take the old motor off once and it didn't leak when I reattached.
Clearly I either put it back together wrong or bought the wrong motor. I don't see any seals laying around and everything looked right to my untrained eye.
Any thoughts as to where I should focus my troubleshooting?
