I would upgrade to the Intellicenter with built in SWG power supply, an Intelliflo VS pump and an IC40 cell.
I can appreciate where you are coming from and thank you for your input... it wouldn't be the first time someone said I overcomplicated things.ECO,
Wow, I read all the posts above and if you are as confused as I am right now, we are both on the same page... I see that you are being fed a line of Bull - Stuff from Pinch a Penny.. A VSF pump will not protect your pump itself anymore than a VS pump will do.. The idea that you can set the VSF flow so that when "The heater kicks on" will make the pump increase the flow is just not right.. The amount of flow through the heater does not change when the heater kicks in. It is true that the heater may need more flow to close a pressure switch to allow the heater to work, but there is nothing that the heater does to tell your pump to increase in speed.
An automation system could do this, but it does not make sense to buy an automation system just to control the heater.
My suggestion is to buy a standard IntelliFlo VS (011028) and just set up a couple of speeds.. One for normal use and one for heater use.. During the time when you want the heater running just run at a speed the closes the pressure switch in the heater..
Yes you can install a surge protector.. Do you have one for you house? It is just a likely that electronic equipment in your house will be damaged as a VS pump. The pumps are designed to be outside.. I have a couple of IntelliFlo VS pumps at two rent house that have been running for 10 years and 7 years and they don't seem to mind the weather at all. That said, I have the equipment at my house in a shed.. Either way seems to work great.
You are just making this into a much bigger problem than it needs to be.
You have a bad pump and the Gold Standard of pool pumps is the IntelliFlo VS.
Maybe I just missed something, but after reading all the posts my brain has turned to mush..
Jim R.
It's very old 2 skimmers with the main drain fed into one of them (my understanding of it)If your pool was recently built or has been upgraded to have two main drain covers, then the SVRS option is totally useless, and based on my experience with this pump, something to be avoided at all costs.
Even pools with single drains that have the raised drain covers don't need the SVRS option.
Jim R.
Really helpful, thank you. I was sniffing that the pool shop fed me a line that the VS/VSF also provides the protection (minus the main drain entrapment piece).The SVRS (Safety Vacuum Release System) is simply a vacuum sensor in the pump. It could detect a loss of prime and turn off appropriately, just as it detects a rapid increase in suction caused by a person stuck on a main drain, which is it's purpose. But as was mentioned before, they create alot of nuisance problems, false trips, etc... They are designed to meet the requirements of the Pool and Spa Safety Act, formerly known as the Virginia Graham Baker Act, or VGB to us old pool guys. These are regulations that only apply to commercial pools, (in spite of the fact that little Virginia died in a private inground spa), but safety is a concern of all pool users. If the added safety and pump protection are worth the nuisance and extra $ to you, then get it. It might just save a life, or your pump.
Really appreciate this.. got itECO,
Jim R.
Much appreciate this. Not sure Automation in my budget.. presumably can be added later?If you want to keep your existing SWG and get a cheaper option, you can use an Intelliconnect from Pentair.
It will control the Intelliflo pump and the heater and on/off for the SWG.
Pool Automation
Pentair's pool automation systems give pool owners full control of pumping, heating, sanitizing, water chemistry, water features and lighting. Learn more here.www.pentair.com
My friend, that is the very definition of automation.just don't know why that can't be accomplished without Automation...
