Morning Folks,
I've had a bit of an interesting development. I have a pool/spa setup with shared suction/discharge valves that are switched by a pair of actuators. The other day the suction actuator failed, and caused all the water to be drawn from the spa into the pool.
I came outside to find the spa bone dry, yet the pump (Intelliflo VS) was still running. Not sure how long it was like that but max 1-2 hours.
Anyhow, I've resolved the actuator problem, but now I seem to have developed a leak on the discharge of my pump casing. Not sure if this could have been caused by the dry running pump, or just coincidental, but either way it's leaking now... (Video below).
What I'm wondering is how one typically deals with a leak at this location. From what I can see, it's a threaded fitting, but there's also a ring of silicone around it as well. I could replace the silicone, but am doubtful that it could truly keep back pressurized water over time (maybe it actually can?).
As far as a repair, it seems like I would be into some cutting and gluing. Either end of the piping between the pump and filter is threaded, but the way the piping is laid out in-between, I don't think I'd be able to spin the assembly off. (Photo Below) So, I probably have to make a cut, get the piping off the pump, then re-tighten and re-glue?
I'm ok with the cut-and-glue if that's what I need to do, but beforehand I want to make sure that's actually the proper solution. Any suggestions on best fix?
Thanks!
Thanks!
