Hi Everyone,
My old pump had lost power and getting noisy so I replaced it with a new 2hp pump (was 1.5hp). The problem is the filter would not fill and no pressure. The new pump is doing the same thing. It does not prime properly so I think suction line leaking. Ran a new pipe from the pump directly into the pool and now it works fine. Will replace/repair the suction line. The bigger PROBLEM is the filter will not fill or build pressure. I have checked the lines for obstructions and took the diverter valve apart and it is fine. Any suggestions? Thanks in advance. Paul
