And where is the thermometer? I always just look at the temp on the screen of the easy touch
Use the pole to see how deep it is.How do I do that?
Macy,We do use the spa often. I also heat the entire pool often enough because this time of year, although warm enough for me, I have a disabled son and I heat it to 90 for his comfort at times also.
So I turned the speed down to 2000. Setting is still at 12 hours a day. Should that be different? Also, when spa is on, that is set at the high rate also, should that be at 2000 as well?
Salt cell is set to 40 percent for pool and 2 percent for spa. Is that right? Maybe all this can wait on water levels.
There is a pool store nearby that is privately owned and run by a family, all same employees. I would trust them to give an accurate water test result level. Maybe I should bring a sample in while I’m waiting on the test kit I ordered?
