I recently upgraded my Compool 3600 to the EasyTouch Upgrade Kit, and I'm banging my head against the wall, trying to understand how to program it correctly.
I don't think my cleaner is working correctly and I'm confused about Spa vs. Spa Low. I was just trying to match my previous system/setup.
Here's how I have it programmed. Any red flags?
Circuit Names
Circuit #1 / Circuit: Spa / Name: Spa
Circuit #2 / Circuit: Pool / Name: Pool
Circuit #3 / Circuit: AUX 1 / Name: Cleaner (should my cleaner go on AUX 2?)
Circuit #4 / Circuit: AUX 2 / Name: Spa Low
Circuit #5 / Circuit: AUX3 / Name: Spa Light
Circuit #6 / Circuit: AUX4 / Name: Pool Light
Circuit #7 / Circuit: AUX5 / Name: Air Blower
Circuit Function
Pool, Mstr Pool, Freeze: Yes
Spa, Mstr Spa, Freeze: Yes
Cleaner, Mstr Cleaner, Freeze: Yes (Not sure what the difference is between "Master Cleaner", "Cleaner", and "Generic"
Spa Low, Generic, Freeze: Yes (is this correct?)
Spa Light, Generic
Pool Light, Generic
Air Blower, Generic
Equipment:
Pentair IntelliFlo Variable Speed Pool Pump EC-011028
Pentair Booster Pump EC-LA01N (just added) - Cleaner
2 HP WhisperFlo WF-28 C Spa Pump
Raypak P-R406A-EN-C Gas Heater
Pentair EasyTouch Indoor Control Panel 8-Circuit 520549 (just added)
My spa spills over into my pool (which turns off when I use the spa). There's a water feature out of the bottom of my spa (not used other than water comes out of it). I also have a waterfall separate from the spa.
The valves seem to work correctly if I hit the valves button on the board. The pool light and spa light work fine (independently).
Circuit Names
Circuit Function
Spa Light, Generic
Pool Light, Generic
Air Blower, Generic
Equipment:
