Hello everyone,
We had our 33' above ground round pool installed approximately 2 years ago. We got sucked into the whole Pristine Blue thing and have been using it since the pool was installed. After reading several forums and doing some reading on the PB website, my wife and I have decided to get rid of the PB and switch over to chlorine. I've read that we will have to completely drain our pool in order to get rid of the copper, or we have to go through a very lengthy process to change over to chlorine. I really don't want to have to drain the 30,000 gallons of water again for about the 4th time since the pool was installed. We've had issues since we purchased the pool but that's all for another discussion. Is there any way that I can make this change without a complicated process or draining the pool completely?? I have spent so much money on chemicals and time trying to keep this pool clean for my family that I'm almost to the point I'm ready to just give it up and take down the pool and eat the $7000. we spent on the pool and chalk up all the chemical and other costs as a very expensive learning experience. Any help I can get with this would be greatly appreciated. I checked the copper level this morning with the cheap kit that was advised we use, and the level is about 0.3. My pH level is low and alk level is around 110. I'm planning on putting 3 pounds of shock in the pool this evening. I haven't put any PB in the pool for about 2 weeks. Thanks all for any help I can get!
