Pressure (Water) Test - Result?
Texas Splash
52,087
Fiberglass
CircuPool RJ-45 Plus
I need some feedback from some of our ITI's like @AQUA~HOLICS, @1poolman1, or @Poolbreh. I have suspected a suction line leak for a while due to a large drop in pump pot water and loss of prime on several occasions the past couple months. I did a temp above ground suction line from pump into the water and the pump is holding water much better with no loss of prime. To me it seemed like validation I have a cracked line, and I suspected under the skimmer.
So I fabricated a replica of a testing manifold, much like some of the leak detection companies use (see below). I have a very simple suction line that goes about 25 ft from skimmer to pump. I used a Safe-T bladder plug in the PVC before anything at the pad to eliminate any valves, fittings, etc. So manifold to bladder plug that's it.
I increased the water pressure to 12 and timed it. Over the course of 20 minutes it dropped from 12 to 7. So I lost about 1 psi every 5 minutes. Does that seem like reason enough to investigate? I have a concrete saw and jackhammer reserved. Decking all marked and ready for surgery. Mentally I'm all ready to go in, but I expected to see my gauge fall more & faster. Now I'm wondering if it warrants the work - for now. Thoughts?
Pressurize the line with air and then listen above the suspected leak location and you should be able to hear air bubbles escaping if you have a leak.
Alternate between air and water pressure.
I would if I could, but I don't have a deck plate or sound rod. Those things are crazy expensive.
With a completely tight system there would be no pressure loss.
Reactions: Texas Splash
