Good morning,
Our pool filter is staying at 35 psi. We have pulled the filter apart, cleaned all of the panels, refilled with proper amount of DE (per the manufacturer instructions). The filter PSI starts around 15 and creeps to 35 within an hour. By the morning the skimmer basket in front of the pump is dry, the pump is priming, and tons of air is shot out into the pool. This morning while taking a look at the pump I noticed that there was enough pressure to push open the backwash valve when shutting off the pump.
Why are trying to figure out where to start on this. Since the water isn't circulating, the pool is green.
Thank you!
Thank you!
