Husband and I are hoping to start our first ever new pool build this fall. We've gotten several PB quotes, and are leaning towards one. See details below. Any and all help/input on the contract would be appreciated. Thanks in advance!
only, if necessary. Temporary construction fence as well as erosion type fence is also
included. If extraordinary underground conditions arise such as rock, water, or fill, there
may be extra costs involved.
reason, the homeowner will pay the engineering firm directly for the exact amount of
engineering that is required.
floor returns. Floor returns increase solar heat gain by taking heated water from the pool
surface and injecting it up through the floor. Two large turbo skimmers provide up to
twice as fast surface skimming with safety compared to a typical pool skimmer.
provides the structural strength to retain the weight of the water, 8 1/2 lbs per gallon. We
use ½” bars throughout the structure and extra wide bond beam will have 8, ½” steel rebar
for extra strength. Steel provides the tensile strength to give your pool shell structural
integrity and provides you with the peace of mind that your pool is stronger and will last a
lifetime.
pads, tunnels, bridge reconstruction, water tanks, dam repairs, steel mill ovens and large
commercial swimming pools as well as better built residential swimming pools and spas. It
is important to know that your pool builder is using the best methods available for the
construction of your pool.
more even light throughout your pool. LED lights will operate at approximately 2/3 less
electricity than a traditional incandescent light bulb and will last approximately 30,000+
hours. Traditional incandescent light bulbs have a life of only 5,000 hours.
efficiency as well as low NOX (LESS AIR POLUTION). The heavy-duty cupro nickel
heat exchanger stands up to the harshest applications.
another sanitizer. This system comes with a chlorine dispenser back-up.
you with the initial balancing of the water chemistry and provide initial and on-going
instruction on the operation of your pool PB Warrantees: All warrantees will be
issued on day of indoctrination when no payments are outstanding. There is a lifetime
structural warranty on the pool and a three year warrantee on the filter, pump, and
heater. PB is an authorized service center for the manufacturer and warranty work is
performed by PB’s service staff.
- Pool Dimensions: 39' length, 17'8" width with additional 9' x 9' tanning ledge, 3'6" - 8'6" depth in pool, 9" water depth on ledge
- Pool Size: 770 square feet
- Pool Style: Custom Rectangle with L Shaped Steps and Tanning Ledge
- Plans: The prints and design concepts required for the township and for construction are
- Building Permit: The building permit cost is included and our certificate of insurance is
- Excavation: Normal excavation and machine grading of excavated soil is included on the
- Engineering: Your township will require engineering of your property as part of the
- Plumbing features: Your pool design includes piping for hydraulic efficiency and to meet
- Steel Reinforcement: Designed for virgin soil. The placement of the steel is 6”x12” in
lifetime.
- Concrete construction: Our pools are constructed with dry Shotcrete (also known as
- Steps and Benches: Three steps lead into your pool with the first step enlarged into a 81
- There is an 8’ walk out bench in the deep end.
- Tile: 6” band of mosaic tile around the entire pool.
- Coping: Bluestone tread stock coping 2” thick with a thermal finish.
- Pool Finish: Marbleized plaster with a silicon shield additive. Colors come in white, gray
- Electric: General pool wiring with up to 150’ of wire, 220 volt, and 40 amp service.
- Gas Plumbing: 50 ft. of gas line is included in your quote. For distances over 50 ft. add
- Deck: 950 Sq. Ft. of exposed aggregate concrete with electric bonding grid and matching skimmer
- Pool lighting: Four Glo Brite LED lights, the newest generation of LED lights will be
- Filtering system and circulation system: Pool filtration will be done through a
- Circulation will be provided by a high performance, quiet 1 HP StaRite pump.
- Heater: Sta-Rite High Performance HD heater 400,000 BTU heater has a stainless
- Sanitization: Intelli Chlor system turns ordinary table salt into liquid chlorine. Your chlorine
- Water: Your pool will be filled by water tankers with the last few inches being filled with the
- Cleaner: The Polaris automatic cleaner and pump will be installed to provide automatic
- Startup package and instruction: Our courteous staff will start up your pool and provide
