- May 16, 2022
- 6
- Fiberglass
- Pentair Intellichlor IC-40
Hi there, I have a leak in my 12,000 gallon Fiberglass pool that’s about 40 years old. I’m losing about a half inch of water a day. I’ve done an ink leak test around the jets and found one spot where it does seem to flow underneath the jet around the rubber gasket. The rubber gasket is definitely frayed so this could be the culprit, or one of them. I can only unscrew the eye of the jet and its surrounding housing, but this leak is under that and would require me digging behind the wall of the pool, which is doable, but not ideal. My other idea was to drain the pool below the leak, rip off that gasket and seal it with something that would be ok underwater in a Salt Water pool, what that would be…maybe you could help. Or if this idea would even be feasible. I also have replacement gaskets that I could possible jam in there, but I don’t know if that would work without proper tension against the housing and the pool wall.
