Popped Pool in DFW?
Talk to local pool builders and companies. They should know your local environment the best. It can happen anywhere you have a high water table. We can't assess your local geology.
There is a post somewhere here on the forum showing a pool popped out in the Dallas area. I am searching but not coming up with it.
Was in the last couple years. After a big rain storm.
There should be a hydrostatic valve in the in the pool that you should make sure is open if you do drain.
More importantly, why do you want to drain it?
Thanks, all. I do not WANT to drain it, but, I have a pool leak that is dropping about 3/4 of an inch of day and I have identified it is likely my main drain.
I have a guy coming to fix it on Thursday, but, at my deepest my pool is 9 1/2 feet deep and there’s only about 3 feet of water left in it.
i’ll go ahead and add water just to be safe.
I wouldnt fill it all the way back up if it is already that low. Maybe you need to add some water to it, maybe not since 3 feet of water in a 13k gallon pool weighs a lot. I would be curious what other have to say.
Good luck with the leak and hopefully the fix is relatively painless.
Thanks!
check this out...
That is driving me nuts! I can see it in my head how it was popped and tilted. Maybe @Jimrahbe will remember it? I think he replied to that thread. But I couldn't find it either.
Pat,
Sorry, does not ring any bells with me.. ?
Although anything is possible, but I don't believe that pool popping of gunite pools here in the DFW area happens too often.
If you can dig a 3 or 4 foot post hole in your backyard and it does not fill with water, I suspect you will be just fine.
And... I would not be surprised if no hydro-static valve is even present. I have had two old pools replastered and neither of them had anything but a single main drain pipe.
