Second year pool owner and new to this forum because I've exhausted all other resources and I'm exhausted. I have a 28ft round, above ground pool built into our deck that's 13,600 gallons. Pool was cloudy all of last summer. Opened this spring and it was clear the first 30 days. Now is back to turquoise and cloudy again. So frustrating and aggravating the time and money I've put into this. If i can't get it clear enough to enjoy it this summer, I'm seriously thinking about having it removed for good!
I've learned a lot these last 2 weeks trying to find a solution and now realize the importance of maintaining balance of chemicals in a pool. Everything i have done so far has not worked. I have now purchased my own at home test kit. Here is what I know, and what I've done so far. I found out it was high on phosphates which seems to be why my chlorine wasn't working well. Everyone just kept telling me to shock it, that has not done anything. I recently added a phosphate remover, still cloudy. But now my chlorine has stayed more consistent. I'm vacuuming twice a week and I've replaced the sand in my filter this season.
My PH is now at 7.8, chlorine at 4 ppm, alkalinity 170. I wait a couple days each time to see results but nothing changes. Only thing I've added was the phosphate remover, then a little bit of muriatic acid, and a little chlorine every couple days. I'm to the point of thinking about draining it this weekend and starting over fresh. Should I drain and refill? If I were to keep putting heavy doses of chlorine in it and waiting would it eventually clear up? I'd like to use it this summer, but it's becoming less hopeful and this pool has been nothing but a major pain and expense. I'm taking a sample in tmw to the pool store to have them double check my cya levels one more time before i drain it this weekend. I'm stuck and I'm out of things to try. Thanks in advance for any advice.
Brett
Brett
