Got it! Pulling steps out now and I'll take them apart.Just thinking, Maybe your addition didn’t actually reach your target
Not on them - IN them
CYA reading between 31 and 39 gets rounded up to 40.CYA 35
Mine only come apart so far it appears. I'm worried about the holes where water gets on the inside. I've drained them though. I'm going to do the same. I scrubbed them with bleach today and I'm going to let them sit out for a few days in the sun.Taking the assembly apart and cleaning each individual part is the key.
Some find they need to add holes to inject liquid chlorine and allow for water flow/easier cleaning in the future.Mine only come apart so far it appears. I'm worried about the holes where water gets on the inside. I've drained them though. I'm going to do the same. I scrubbed them with bleach today and I'm going to let them sit out for a few days in the sun.
Going over slam fc level just allows for even faster burn off of chlorine.Still slamming. Still adding chlorine. Still dropping pretty fast. I'm over 50 gallons of chlorine in the last 3 weeks. I have removed the stairs and weights from my pool. I'm adding over quite a bit of chlorine each time but my levels still drop quite a bit. Slam been going on for 4 weeks. What am I doing wrong? It's still not tfp clear. I'm off the next 3 days and will be sure to test and add every 2 hours.
Sand filter. Pump has continuously been on over 4 weeks. I replaced sand beginning of season before slam. I've been slamming for 4 weeksGoing over slam fc level just allows for even faster burn off of chlorine.
(The higher the fc the faster it happens)
So aim for slam fc to be the most efficient.
What type of filter do you have
Ok thanks. I bring my chlorine levels back up to slam, but then like this morning it dropped from 16ppm to 7ppm. It's driving me crazy and requires a lot of time and chlorine. I've got the stairs and weights out of my pool. I get in it to brush and vacuum and scrub, but still losing chlorine at a rapid pace. It's frustrating when you don't know what it is and the amount of trips to go get chlorine and the amount of money I've spent so far. I'll go over everything again today. Now I know when I hear everyone say what a pain pools are and to get rid of the thing! I want to give a it a fair shot, but I don't want to be doing this every summer!FWIW, I added DE to my sand filter following the instructions I found here. I think it’s helping my situation. Regardless, you’re fighting algae or some other organic infestation. You’ll have to get down to every last bolt, nut, screw, junction, crease, fold, etc to find and kill it. I got lucky and found my culprit quickly.
The idea is to never have to do theOk thanks. I bring my chlorine levels back up to slam, but then like this morning it dropped from 16ppm to 7ppm. It's driving me crazy and requires a lot of time and chlorine. I've got the stairs and weights out of my pool. I get in it to brush and vacuum and scrub, but still losing chlorine at a rapid pace. It's frustrating when you don't know what it is and the amount of trips to go get chlorine and the amount of money I've spent so far. I'll go over everything again today. Now I know when I hear everyone say what a pain pools are and to get rid of the thing! I want to give a it a fair shot, but I don't want to be doing this every summer!
