cwswifty
- Sep 14, 2023
- 259
- Plaster
- Jandy Aquapure 1400
Your ph will rise on its own as your ta is 220.Been monitoring the pool. I continued to slam until last night. Passed an oclt test. Pool is pretty darn clear. Here are my current numbers from 11 am this morning. It is 99 degrees and sunny here. Pool gets full sun.
FC: 10
CC: .5
PH: 7
TA: 220
CH: 160
CYA: 30
Pool math tells me to add 15lbs of borax to achieve 7.8 on PH. I know I want to start slow by maybe doing two-thirds of that at first. I'm I ready for that? Thanks.
I do notice my fc drops pretty rapidly. It will hold overnight but can drop 3-6ppm within 3 hours after the sun comes up. Is that normal?"Pretty darn clear" means you probably aren't quite done with the SLAM Process.
How Clear is TFP Clear?
With a TA of 220, your pH of 7.0 will rise on its own. No need to add any chemicals to addrrss it.
NoI do notice my fc drops pretty rapidly. It will hold overnight but can drop 3-6ppm within 3 hours after the sun comes up. Is that normal?
What you're describing is UV degradation of chlorine. How sure are you about your CYA level being 30 ppm? If it really is 30 that is pretty low. But if it is possibly less than 30, even worse.I do notice my fc drops pretty rapidly. It will hold overnight but can drop 3-6ppm within 3 hours after the sun comes up. Is that normal?
Sorry I'm just now seeing this. My cya started a little closer to 40. It is now closer to 30 using the Taylor test kit. I am still slamming. I haven't been able to do it as often this week as I've been busy at work but I'm slamming first thing in the morning, checking before I leave for work, then when I get home, and again before i go to bed.What you're describing is UV degradation of chlorine. How sure are you about your CYA level being 30 ppm? If it really is 30 that is pretty low. But if it is possibly less than 30, even worse.
I will just have to find a way. I will be off 5 days over the 4th of July holiday. Just seems like a lot of time and chlorine. Still can't believe the pool is this much workYou will have a long road to clear this pool, if you can only test and replace 3x per day. Do you have anyone that can test and replace during the day?
The weekend is also a great time to get ahead. If you can test and replace every 2 hours, you can get ahead of this...
It took a while to get bad, it will take a while to clear it.I will just have to find a way. I will be off 5 days over the 4th of July holiday. Just seems like a lot of time and chlorine. Still can't believe the pool is this much work![]()
No I didn't do a true oclt test. I've just tested it enough over the last 3 weeks to know it's not holding. The first week it did better. Losing more and more now. I'll pull the steps tmw and see if maybe that could be the culprit. I always scrub them but just maybe there could be algae on them.Did you do a true oclt last night (testing after your last addition?)
Have you yanked your steps & cleaned them inside & out? Check the weights too.
Thanks for that. I'll give it a shot.The ladder is what nailed me. Once I took it out and apart it revealed itself to be the demon spawn of algae. Just taking it out started the path of good chlorine readings.
Just thinking, Maybe your addition didn’t actually reach your targetNo I didn't do a true oclt test. I've just tested it enough over the last 3 weeks to know it's not holding. The first week it did better. Losing more and more now.
Not on them - IN themI'll pull the steps tmw and see if maybe that could be the culprit. I always scrub them but just maybe there could be algae on them.
