Hi. This is a newly refinished pool with diamondbrite. It was completed 1 month ago. Chemicals have been pretty much perfect over the past month with daily brushing of the surface and a brand new filter. Salt has not been added to the pool until this morning. Approximately 1 hour after adding the salt, the pool turned a greenish color. The water is still clear (you can easily see the bottom), but green and there has never been any obvious algae in this brand new pool (chlorine has been consistently maintained at 3-4 ppm). Here are the current test results. Everything is within the normal range. Please Help. Leslie's pool store did not know what to do. The manager said, "Maybe add more chlorine?".
Free Available Chlorine: 4
Total Available Chlorine: 4
Salt: 2950 ppm
Calcium Hardness: 200
Cyanuric Acid: 70
Total Alkalinity: 120
pH: 7.4
Copper: 0
Iron: 0
Phosphates: 0
Temperature: 83
Salt: 2950 ppm
Cyanuric Acid: 70
pH: 7.4
Copper: 0
Iron: 0
Phosphates: 0
Temperature: 83
