Can you tell from the attached video how much the slight splashing from the spa spillway contributes to pH rise? It’s the result of the top edge of a tile on the bottom left sticking out slightly. The pump is running at low speed and the water coming into the spa is from the bypass line, which is fixed (no automation). The pump runs daily at low speed for 9 hours and at high speed for 2 hours.
