So i was under the assumption that my tests of my salt levels were accurate because i use the drop test. But I recently took a sample into the national chain store and they told me my salt was really low at 2300ppm. The guy used some type of electronic tester. Is this the most accurate method and more accurate than drop test? Not sure why my readings were so off, chemicals are not even near expiration. In this instance I’m apt to believe their test as i added 80lbs of salt and now my cell is working again. Any thoughts?
