Hello everyone.
I have a big pool (30.000 gallons) with a sand filter.
For the last 3 months I kept it balanced correctly, PH between 7.2-7-6, ALK between 90-110, FC between 1 and 5 ppm. But still every 3 days, I have green algae on the wall and bottom, but as soon I touch it fly away (like light powder).
FYI I keep my pool covered with a solar cover and a chlorinator to keep the pool with a minimum of 2 ppm (by the way I felt the tab dissolve fast 10 tabs every 1 week to 10 days without have a FC crazy (never higher than 4-5ppm))
Also I recently figured out that he spider gasket from my sand filter was damaged (I figured it out when I put the filter in recirculate and water went out through waste), so I ordered a new gasket.
Last weekend I traveled for 2 days, and the bad things began while I was gone, the water turned completely green. We changed the spider gasket as soon as we got back, then read online, if you have algae, you need to "hyperchlorinate", so I put 7 bags of shock (the 1 lb. 73% Calcium Hypochlorite from Leslie's) overnight, backwashed the filter the following day, and hope the best.
2 days after the pool is still green, and cloudy, a bit less but still.
So considering the shock didn't work, I decided to put HTC Flocculant.
When adding flocculant you should keep running the pump in recirculate for 2 hours and let the product work overnight.
Almost 48h later the pool is still green, and I am feeling it's getting worse and worse (not running the pump to let the flocculant do its job, so no chlorine added).
In addition, at every step, I checked my PH, ALK, FC, CC and kept them at the correct range (except for the chlorine for the last day).
I went this morning to Leslie's to chave my water tested. All the results came back within range except for the phosphate which high (200ppm) and chlorine at 1ppm. So he advised me to put the "no phosphate" product in our pool.
But after doing more research today, I am hesitating as the phosphate remover will not make the pool clear. So I am not sure what is the next step from here: wait a bit more for the flocculant to work (so far nothing more than 24h after putting it in the water), add shock? add the phospate remover product? add algae remover (Green to Clean) product?
I am also worried to put the filter in filter mode because of the flocculant in the water which would clog it.
Any input on this would be highly appreciated, thank you!
