Hello...our pool is under construction. We have a raised spa that is 16 inches above ground, will spillway onto the tanning ledge.
my PB has said that tiling the top of the spa (where you would sit and turn to get in, so not in water) is not advisable, as the grout would be very rough when you to sit and turn to get in. he thinks putting travertine is a better option. Although given the rough surface of travertine, I think travertine may also be rough on the skin...one of the folks that works for the builder also felt there may not be any difference.
I will likely go with ceramic tiles rather then glass.
Our decking is travertine.
I like the clean lines of of the spa with using tile. I am open to 1x1, 1x2, etc...basically any size that will produce a very clean line look.
any thought would be helpful! Thanks!!
