- Nov 12, 2017
- 12,698
- Plaster
- Pentair Intellichlor IC-40
Don't use strips. Don't use pool stores.
If you suspect your CYA is either 0 or 40, and you need to get to 70 for your SWG, that's easy, and you can kill two birds with one stone. Use Pool Math to determine how much CYA to add to your pool to get it to CYA 30. Let us know if you need help on how to add CYA. Let the new CYA mix in really well, like a day or two (while keeping your FC up) and then test using your Taylor Kit. If you get 30, then you'll know your reagent is OK and that you were really at 0 to begin with. If you get anything else, that means your CYA was originally somewhere between 0 and 40, just not enough to show up on the Taylor test, and now you'll have a testable amount. Then go back to Pool Math to calculate how much more to add to get to 70 (or whatever your target is).
It's prudent to add CYA in chunks like that anyway, taking up to a week or more of adding and waiting a day or two between additions, to "creep up" on your target. CYA can take a while to mix in and then show up on a test, and by creeping up on it you can avoid overshooting, which can only be fixed by exchanging water.
So maybe shoot for 30, then 50 or 60, then 70, like that.
