Bill1974
- Jun 18, 2014
- 700
- Vinyl
- CircuPool RJ-60 Plus
Tough to determine how much dirt got in but I don't think it's an issue. Probably could vacuum to waste to get it out. You will likely get some mortar and concrete in the pool when the slab is poured and when the copping is installed. Getting that out is more fun as it generally plugs up the head of the vacuum and you have to drag it out of the pool, shut off the pump, reprime and repeat. If you can keep the pool clear it will help. Mine turned to a swamp and I vacuumed blind to get the bulk out before I closed the pool. I was already running into freezing weather.
