Hey folks - need a little advice.
Situation - pool was drained and refilled after some plaster polishing.
Got the following results results my Taylor K-2006C
FC - 0
PH - 8.2
TA - 130
CH - 200
CYA - 0
CSI - .52
Temp 66
8,600 gallon pool w spa.
I am confident I know what chemicals to add using to calculator...but which do I address first?
Also, I have a chlorinator (using 3 inch tabs) that I shut off because it made my CYA go sky high last year. What is the best way to get my CYA up? Just use straight CYA or use the 3 inch tabs to help bump it up or maybe even shock?
Thanks in advance!
FC - 0
PH - 8.2
TA - 130
CH - 200
CYA - 0
CSI - .52
Temp 66
Thanks in advance!
