Hi all,
I was cleaning the pool this morning after the storms in California and ran into an issue after emptying the pump filter basket. When I went to turn the pump back on, I heard a humming noise, but nothing was moving. After reading some threads and watching some videos, it seems like the next step should be trying to manually turn the pump shaft and/or replacing the capacitor.
We are renting the house, but a crafty lease has us responsible for the pool maintenance, repair and equipment. I'm not sure when it was replaced, the old one was left sitting right next to it, or if there are any sort of warranties in play.
Pump: Xtreme Power US Model: 75034
I'm open to trying to manually turn the shaft or even replace the part, but I wanted to make sure my logic was sound before diving in.
Attached at pictures of the pump, filter, and electrical setup I'm working with. Please let me know any tips, tricks, or "gotchas" if you have any.
The plan
A. Does the plan sound correct? or should I be considering a pool professional to do this instead?
B. Where can I test with a multimeter to make sure the power is off to the pump?
C. Is there a way to test the capacitor and see if it's good? Should I try to replace it?
Video of pump humming:
The plan
- Flip the "Power Disconnect" switch
- Test the pump doesn't turn on.
- Verify w/ multimeter there is no current/power to the pump? (Any advice where to test on the pump for this?)
- Remove the 2 rusted bolts on the pump cap
- Manually turn the shaft clockwise to try and dislodge any debris or corrosion
- Test/replace capacitor? (Is there a way you can tell it is bad?)
- Close it back up, enable the power again, and turn on the motor
- Repeat steps 4-5 if still hearing humming first time
