My single-speed pool pump motor is dead and I can't get it off my old Anthony bronze pump. If pools were meant to be green I'd have a beautiful one right now. I want to make a bunch of changes anyway and I'm thinking of just redoing everything except the heater and Zodiac Z4/iAqualink automation system, which work well. My main design goals are ease of maintenance and readily available/cheap parts, and maintaining automation. I travel a lot and can't babysit a pool every day.
I have 2" PVC everywhere, except for a small section of 1.5" bronze coming off the pump head. Pad is 30-50 feet from various points at the pool, and is slightly elevated. I'm thinking of running 2.5" PVC on the pad to allow for additional flow from the various intake/return 2" lines. Most of the time I would run at lower RPM though, so LMK if I'm overthinking this and should just stick to 2" on the pad.
I have chronic algae problems and lots of trees around. I want to convert to a very oversized SWCG to give myself a shot at keeping chlorine up post-SLAM. The CircuPool RJ-60+ looks like a good contender. I understand it won't interface with the Z4, but I'm not clear I really need it to. Open to suggestions.
My Anthony DE VA-52-2 filter has been overhauled a bunch of times and works, but with the bronze push/pull valve and piping that is bronze all the way to the pump head, I'm looking hard at replacing it with a large cartridge filter (CCP 520, SwimClear 525, WaterWay 525, or other).
For a pump, I think I have a 1.5HP impeller currently. I've had a range of motors on it (I think... presently, a dead 1.5HP x 1.5SF motor = 2.25THP, and previously a motor with a 1.65THP rating I think). The in-floor heads and spa jets work OK - could be better. The Z4 manual indicates compatibility with Jandy pumps and Intelliflo VS pumps. I have a 15A, 240v circuit for the pump. A large basket and 2.5" unions would be a plus, depending on advice above. I'm not clear what the best choice would be.
Air Blower makes tons of noise. It has its own 15A, 240v circuit.
I've been reading on this site for years, but I'd really appreciate help tying all this together!
