I've gotten lots of good info from this site over the years, and have had many questions answered. Some, however, I've answered for myself, and now will be posting a series of topical guides to things I've figured out that other folks may find useful.
I just did a complete overhaul of my pool pad, replacing a very old Anthony bronze 1.5hp pump and VA-52-2 DE filter with new gear. I wanted the Intelliflo VSF 011056 pump. One issue that arose is that my current wiring is a 140ft run of 14ga conductors, coming off a Double Pole 15a breaker. This will not support the Intelliflo at full potential output. Further, voltage drop at that distance is a major concern. 8a is about all I can draw at that distance without losing more than 3% voltage (house voltage starts at 237v). However, 6a x 230v is more wattage than I need to maintain flow rates of 75GPM in my 2" plumbing.
Because you can limit the max RPM, and because 2" plumbing introduces enough restriction anyway to limit flow and therefore wattage, running the Intelliflo here works fine. I made a video showing in real time the voltage drop at various RPM and flow rates.
Here, also, is a table of my starting GPM/PSI for a fairly clean filter. (a dirty filter increases restriction and therefore reduces flow and wattage at a given RPM).
3100RPM; 77GPM, 26PSI at pump; 1726w; 14PSI at filter
2700RPM; 68GPM, 20PSI at pump; 1168w; 10PSI at filter
1700RPM; 40GPM, 7PSI at pump; 305w; 1.5PSI at filter
1100RPM; 24GPM, 3PSI at pump; 91w; 0PSI at filter
Hope someone finds that useful.
