- Jun 7, 2017
- 9,984
- Plaster
- Jandy Aquapure 1400
Just digging it deeper I don't think will suffice. There is the whole grade of the bottom and integration into the sides. I really think to do this correctly it needs to be started over. Gunite can be sprayed in phases over time but that is when the job is correctly set up for it with rebar spanning where it is supposed to go and not just cut and pasted back in.
Does your builder offer a lifetime guarantee on the gunite shell also guaranteed by a third party or a fund in case the builder should go under? Mine does.
I think if you press it enough, the builder might just walk away and tell you to sue him. This will tie you and your money up and put you without a pool until it is resolved. You are in a bad situation. I hope it all works out. I would not settle for a pool without a deep end. I got 9 feet and wanted to go deeper than that. What makes it worse is you told him about this with plenty of time for it to be corrected before the spray.
