ktmorgan
0
I want to help test but the iOS link is not working for me. Says "We're sorry but something went wrong". Any idea what's up?
It's a good start, but right now it is pool log, not pool math. Need chemical addition Calc.
If you click each chemical in teh overview, it will take you to a window for that chemical with pool math for that chemical. SO the calculations are there, just in a bit different format.
I agree that re-sorting the readings is useful - CC and FC grouped together.
I do have a few wishes/suggestions:
1. Allow tracking of pump run time in addition to SWG output %
1a. I have a cover and my SWG runs at a lower % when it is covered vs un-covered - it would be nice to have this SWG % tracked as well - it could be toggled on/off as most users would never need it.
When was the last time you updated your CYA level in the log? If it's been awhile enter a new CYA result and see if it matches. We are using the same code now between the App and webpage so the results should be the same. By entering in a new cya levelmit will "force" the App to update its results. Additionally make sure you're updated to the latest build. You can check this in Test Flight. If they still don't match can you PM me with your pools settings so I can try to recreate.
Hi all, Can you please confirm the name of the app is "Pool Math"? I tried to find it by this name in Google Play but no luck. I am in Canada so not sure if that has anything to do with it. Any Canadians who managed to install it? Thanks!
I would be happy to beta test. Computer nerd by trade and everything. How do I find it in the Apple App Store? Edit: Tried the poolmathapp link in a previous page of this thread and it doesn't work. Sorry if I missed the obvious.
Look for it. It's in this thread at least 5 times...
See posts #89, #149, and #228...
