Hi, We just bought a Coleman power steel deluxe series, 18x48 model. We researched how to choose and prep the area in advance…mostly following advice found in this forum and watched a ton of videos to make sure we did it correctly. We’re both meticulous and fairly handy people. We leveled the area by digging out the dirt and the pool is sitting on 1” pink insulation board. The legs are on 7x10.5x3.5 paver blocks that we dug down to level with the foam and they were leveled to each other. The pool is quite level, only off by less than 1/4”. The legs were all level/plumb front to back and side to side at the start and continued to adjust throughout the fill.
Now that it’s been up for a week, it seems the liner has pushed the legs out of plumb. Some legs are at the outside edge of the pavers, or overhanging. Others have only moved a bit. And the problem isn’t confined to one side of the pool. It’s off around the pool at varying degrees.
Currently, we’re draining the pool down to where we can safely lift the legs and bring the pavers out a bit. However, the legs will continue to be out of plumb if the liner pushes them out once the pool is filled again.
Is it normal for this to happen or is it an indication something is off? Is there a way to prevent this? Thoughts?
Thanks in Advance
Thanks in Advance
