Stay powered down & test continuity with new bulb in fixture.
I measured 12v AC at the load cables right off the transformer. I did not unravel them, but that shouldn't make a difference. At the bulb socket, I measure zero, nothing.. no matter how many times I switch volmeter contacts; I touched the socket wall with 1, and the center point with the other. Therefore, it might be time to say that the light fixture is bad.
I never thought of that since I had a reading at the socket in my last tests a month ago or so. I will check it as well as test the continuity as you described it.Am I understanding that your light fixture cable run straight to the transformer? Don't you have a junction box to inspect the wiring connections!
As long as you can get a new one that fits your niche, sure you can do it. I've seen them done with out draining so sure it can be done. Sometimes people have issues pulling the old one out.
Your existing junction box should be at least 8” higher than the pool or spa water level and there is no concern for water going up at the junction box level. Except for a wet lighting cable that you just pulled.It looks simple enough, as long as the old and new cable pulls go smoothly. The tube out of the junction box has 3/4" diameter, so that will make it easier to pull. The video mentions nothing abkut about the fact that once you start pulling the old cable out, water will go into the conduit tube going back to the junction box; perhaps, it is not a concern.
NEC Article 680.24 Junction Boxes (explained)
(2) Installation.
(a) Vertical Spacing. The junction box shall not be located less than 4 in. above the ground or pool, outdoor spa, or hot tub deck, or not less than 8 in. above the maximum water level.
First off, get the gunite niche model # and order a replacement light fixture. Take into consideration the extra 5’ length of cable. INYOPOOLS.com should be able to help you out on this.
(2) Installation.
At the junction box, see if you can pull the old lighting cable with ease. If so, cut the old cable near the light fixture and secure the new cable to the old one. I soldered together the old wires to the new one. Also, I bought a bottle of cable pulling lubricant from Lowes but did not use it. Having able to pull the cable one way at the junction box side will save you time and effort. But if the cable won’t budge either way then get ready with a fish tape or perhaps time to engage an electrician.
I learned how to replace our Spa and Pool light fixtures by watching youtube videos. In fact, my very first cable pulling experience and it went with ease. I should say, the $1.5k quote for parts and labor motivates me to DIY!
Good luck!
Water inside the conduit is normal as long as there is no leak!
Post pictures of your existing light fixture. Focus on the label if any. An expert should be able to steer you in the right direction.
Thanks Meadow. I was given a 12v 25w LED bulb as a gift that I obviously plan to use. I also imagine that any future bulb purchase will be an led bulb.Cool...I'm not an expert but the pic tells it all. Any of the pool type LED fixture in the below link will fit your gunite niche. But of course, you can widen your search. The choice is yours!
