I should have all my information in my pool logs, but wanted to verify I'm on the right track to start SLAM!
Test results after 30 minutes of pump running:
FC - 3
PH- 7.0 (could be a little lower)
TA - 40
CYA - 0-20? Dot could still be seen at 30 (i did close pool with CYA in it last September )
Salt- didnt test
Temp- 55
I am treating pool as a NSWG pool, until temps get higher and SLAM is completed
I added 31 oz. of dry stabilizer (based on 20 CYA to get me to 30) and will test again tomorrow afternoon
Added Bleach to get me to SLAM level of 10 based on CYA of 20, but will adjust after I test CYA tomorrow
Should I SLAM at SWG levels or SLAM at regular levels and keep CYA lower? Im thinking since water is so cold, its better to SLAM at NSWG numbers.
Thank you!
Becky
FC - 3
TA - 40
Salt- didnt test
Temp- 55
Thank you!
Becky
