Which Chemical First
Get 10 ppm of CYA hanging in a sock in front of a return. Lower the PH .4 at a time until it's a low 7.
Then SLAM Process. Target will be 12 FC for 30 CYA. Check it after a few days once it's had time to register. 20 and below are sketchy to read and you may need more than 10. (But don't want to overshoot)
Reactions: Brian PacNW
Thanks for your reply. So I can start lowering my PH while increasing my CYA?
Yes. Add the Muriatic acid away from the CYA or pull/move the CYA sock for the few minutes it takes to add the MA.
