Pool is filling now, wanting to be prepared!
mcuffe0234
19
Minnesota
Hi there!
I tried to see if this was posted already and in the pool school but could find it, so I apologize in advance.
We just installed our 18x52 Intex above ground pool. We have a sand filter and SWG.
From my understanding, once the pool is filled, I’ll test the water, put in salt according to what I need, let the pump run for 24hrs to dissolve salt and then turn on the SWG. Is that when I test again and add the of the chemicals I need to get the levels up/down?
Texas Splash
46,544
Fiberglass
CircuPool RJ-45 Plus
As soon as the pool is full you should let the water mix for short 30 min then test all levels. You can expect a zero CYA, so get a sock soaking with stabilizer for a CYA goal of 70. Add liquid chlorine today for an FC target of 2-3 ppm. Get the salt in there too. Tomorrow maintain an FC of around 4-5 ppm and turn on the swg. Monitor for FC production. Oh, and balance the pH right away in the 7 range. That should get you going.
Reactions: clambert1273
mcuffe0234
19
Minnesota
As soon as they pool is full you should let the water mix for short 30 min then test all levels. You can expect a zero CYA, so get a sock soaking with stabilizer for a CYA goal of 70. Add liquid chlorine today for an FC target of 2-3 ppm. Get the salt in there too. Tomorrow maintain an FC of around 4-5 ppm and turn on the swg. Monitor for FC production. Oh, and balance the pH right away in the 7 range. That should get you going.
This is absolutely perfect!!! Thank you so much!
Reactions: Texas Splash
clambert1273
1,493
Gilbert, AZ
CircuPool Edge-40
This is probably a silly question, but while the water is mixing, can I use the skimmer to clean all the garbage that’s been falling into it while filling? Can I also use the vacuum? Or should I wait until all levels are up?
You can operate like normal as long as your actual water level isn't below skimmer
red-beard
1,621
Houston, TX
Hayward Aqua Rite Pro (T-15)
I always add liquid chlorine while it is filling to make sure algae can't get a hold. And a little CYA helps protect the chlorine.
