Pool Filter/Pump don't turn on
Jun 18, 2015
29
Murfreesboro
I have all Jandy/Zodiac pool equipment. I cannot turn the pool pump/filter on despite the Aguapure equipment box is turned on. I can turn the pool light on, so the Aquapure control box is functional. On remote control when you turn the pool pump/filter on, it goes from off to on but a sign comes up on screen that pool filter/pump is offline. I have reset the Aquapure control control box but still did not solve the problem. The pool chlorine level has gone to zero since Salt water chlorinator won't work unless pool pump/ filter is working. I will appreciate any input.
As dom stated, add liquid chlorine in the form of bleach and stir it up manually as best you can.
